Accessing sunroof track....Headliner removal?
I mentioned in my other post that the sunroof cover has slid way back and is stuck and has the sunrof stuck open. I'm going to have to get access to my sunroof track. I'm thinking that I have to remove at least part of the headliner.
Is removing part of the headliner, in fact, the way to access the sunroof track and be able to get to the back portion to pull the stuck sunroof cover forward?
RE: Accessing sunroof track....Headliner removal?
You have to pop the whole plastic cover off the visor tabs and the screw is underneath. Best way is to insert a flat screwdriver in front of the spring plate thingy in the centre and pop the cover of from inside the front face (facing you) rather than from the screen side behind!?
I started off being kind and gentle, but sometimes you've gotta be firm with it!
I'm trying to figure out what's holding the lining around the sunroof opening itself as everything else supporting it is off!! (can't seem to get a reply/response to thatpost tho').
