Adjustable BOV help.
Ok so my cousin has a new Adjustable BOV that was going on his supra, but bought an SSQV.....so he gave me his other one and it looks like a forge 004 but is adjustable by turning the nut on top, and NOT by changing springs. Can anyone help me find out how much to tighten it..im on 14psi. and i have no idea how much to tighten it. He also has another adjustable one but is the kind with a "horn" where it blows off... which one should i take, which one would sound better?
and help me adjust this someone
RE: Adjustable BOV help.
ORIGINAL: kemp_travis
do what i did, take your dv and feel the pressure from the spring, then adjust the bov/dv about the same stiffness, i have the gfb dv/bov but i use it for dv because bov makes my car run like it has the flu
ORIGINAL: Sp33d07
wow, i didn't relize you were a *****. i had always though highly of you TT.
I have tried opening the BOV side of the bfg up and everytime i get a check engine light, vagcom reports the car running rich, i'm sorry, but on MY car, it fu(ks shìt up, maybe it's the EFIs i run.
EDIT:
i was simply stating what i have experenced, sorry if it came across as fact.
EDIT:
