adjustable fuel pressure regulator
Old Nov 11, 2006 | 03:35 AM
hihistan's Avatar
Default adjustable fuel pressure regulator
hi all............i just bought a adjustable FPR with fuel pressre gauge with it........just wondering how much pressre should i set??
i have AMD chipped,k&n filter,performance exhasut with de-cat and spark plugs............thanks for help
Old Nov 11, 2006 | 03:42 AM
Lazer Viking's Avatar
Default RE: adjustable fuel pressure regulator
what the hell is an amd chip ?
you really didnt need one...unless you are planning on bigger mods for the future ?
Old Nov 11, 2006 | 03:46 AM
hihistan's Avatar
http://www.amdtechnik.com/
here is the site for amd chip.............soem shop said it will have better run if u change the FPR after u had ur car chipped
Old Nov 11, 2006 | 04:34 AM
hm, never heard of them, they seem reputible though, uhm i think stock we are set at 4 bar ? if you set it higher i think you could also go bigger injectors
Old Nov 11, 2006 | 05:07 AM
chaos92287's Avatar
hmm...i think the stock one is 3 bar. if your running an aggressive file for the k04 they recommend using a 5 bar one. so i guess your inbetween and should go 4 bar but i dont think its gona help that much.
Old Nov 11, 2006 | 05:45 AM
hihistan's Avatar
em...........thanks................that's what i think the stock one is around 3 bar too...........i'm setting it 4 bar right now
Old Nov 11, 2006 | 05:52 AM
hihistan's Avatar
and just one more question................i have those manual boost controller http://www.ecodetuning.com/shop/cart...ail&p=963&c=46 but i'm not able to increase the boost.............did anyone use those controller b4???
thanks
Old Nov 11, 2006 | 05:56 AM
chaos92287's Avatar
you really shouldn't add more boost without adding more fuel. get bigger injectors to go along with that fpr
Old Nov 11, 2006 | 05:58 AM
hihistan's Avatar
yes i know..........but i'm saying to set for lot more boost.........may be just few more psi .........
Old Nov 11, 2006 | 07:28 AM
BadLuckAudi's Avatar
it doesnt matter if its alot or alittle more its still leaning the car out a **** ton for what it should be, and stock FRP is 4 bar... honestly this stuff your doing isnt gunna give you any more power
ORIGINAL: hihistan
