AudiForums.com
-   Audi A4 (https://www.audiforums.com/forum/audi-a4-8/)
-   -   adjusting E-Brake... (https://www.audiforums.com/forum/audi-a4-8/adjusting-e-brake-62347/)
Lopster99 May 1, 2007 09:16 PM
Maybe im just dumb...
How the heck do i tighten my ebrake??
thanks..
Dennis
auditech79 May 1, 2007 09:46 PM
RE: adjusting E-Brake...
Parking brake, adjusting
https://www.accessaudi.com/elsawebjc...al/hinweis.gif Note[/align]
t
The rear brakes are self-adjusting, so the parking brake does not require adjustment in normal operation. Adjustment is only necessary after replacing parking brake cables, brake calipers, brake pads or brake discs.
t
The parking brake system must be bled and must be functioning properly.
t
The parking brake lever, parking brake cables and brackets must be fully installed.
Adjust lever position at brake calipers using feeler gauges to ensure that A = 1.5 mm.
Depress brake pedal firmly at least three times.
For ease of illustration the diagram shows parking brake lever removed from vehicle.
Press release button -2-. (Both spring-loaded hooks must catch eyelets on parking brake cable).
Let go of release button.
Firmly apply parking brake lever at least 3 times.
Place parking brake lever in rest position.
Press release button. (Both spring-loaded hooks must catch eyelets on parking brake cable).
Remove feeler gauge from brake calipers.
Check lever position at brake calipers.
Distance A between lever and stop must be between 0 and 1.5 mm.
auditech79 May 1, 2007 09:49 PM
http://img406.imageshack.us/img406/7760/cablewn7.th.pnghttp://img125.imageshack.us/img125/1...ble1sz1.th.png
Lopster99 May 1, 2007 10:00 PM
Thanks alot, very helpfull thread!
