Alternator Filter
Old Nov 14, 2005 | 06:53 PM
Diavan's Avatar
Default Alternator Filter
Anyone heard of Alternator Filters... ?
I am getting a weak whinning sound from my sound system on High RPMs.
One of the sound shop guy told me that an Alternator Filter should fix it.
I'm not sure what it is.
If anyone here has done that, I wanted to know how much its gonna cost me, or if it is something simple I may be able to do it myself.
Appreciate that. Thanks.
Old Nov 14, 2005 | 07:23 PM
InsaneHatter's Avatar
Default RE: Alternator Filter
is that like blinker fluid?
Old Nov 14, 2005 | 07:29 PM
jukeit's Avatar
ORIGINAL: InsaneHatter
HAHAHAHA.
Old Nov 14, 2005 | 09:35 PM
Railslider's Avatar
Make sure to check your blinker fluid and exhaust drivetrain often....
Old Nov 14, 2005 | 09:38 PM
AudiTech04's Avatar
Come on guys i think he means something like a radio interference filter
But i think you have a loose ground in the radio wiring
Old Nov 14, 2005 | 09:41 PM
Diavan's Avatar
ORIGINAL: Railslider
Ground Checked. I can recheck, but I've a feeling its not the problem.
Old Nov 14, 2005 | 09:43 PM
Diavan's Avatar
Something like this I guess. ... No clue.
http://www.aircraftspruce.com/catalo.../altfilter.php
Old Nov 14, 2005 | 10:51 PM
BFlan2001's Avatar
alternator whine is a common interference after installing a system. i just installed a sub and amp and i got HORRIBLE interference. you need a ground loop isolator. stinger makes a good one, but i'm sure one of the cheaper ones would do just fine. they are all over the net and ebay for 10-20 bucks. you plug your RCAs into the isolator, then plug the isolator into your amp. it's very easy to do yourself
Old Nov 15, 2005 | 03:25 AM
Diavan's Avatar
ORIGINAL: bentframe
I have the OEM Symphony II system in my 2001 A4. Where do u think this isolator should be installed.
Thanks for the tip though. I can pick it up from Radio shack tommorow, if I can understand where to connect it. I dont think we have amps in OEM Symphonies.
Old Nov 15, 2005 | 03:56 AM
Cameron's Avatar
Blinker fluid, engine oil changes, muffler bearings, etc. All myths.
