Apr 1+ Lean issue
Old May 28, 2007 | 05:53 PM
CRAZYHAWK's Avatar
Default RE: Apr 1+ Lean issue
Spark plugs should be a light tan not white. You're running 7 heat range plugs, which
should help cool the combustion chamber. Can you check with the VAG the air/fuel
ratio?
Old May 28, 2007 | 11:47 PM
crd945's Avatar
I just went out and did a lot more vag logging... 3rd gear pull up to 6400 rpms, the mass air flow g/s only gets up to 150 MAX. The block 32 multi lambda value got up to the low 20's. If the front 02 sensor was not working how would I know, and wouldnt it through some errors that my vag com would detect?
Old May 30, 2007 | 11:49 PM
crd945's Avatar
I bought another MAF from Audi just to make 100% sure the problem wasnt my maf... and as I thought, the maf is not the problem. I am bringing my car in in a few days to the apr tuner in ri. I have 2 mafs for sale.. they both work... if you need one go to the classifieds
Old May 31, 2007 | 11:38 AM
onepoint8tee's Avatar
theguy1084- What is your max boost?
crd945- What is your max boost?
Old May 31, 2007 | 12:03 PM
crd945's Avatar
18-19 max (n75F with a forge 007p yellow spring)
chrfe
Feb 28, 2011 06:03 PM
auditt225
Jul 29, 2007 05:21 PM
spam7788
May 23, 2006 08:53 PM
True_Pinoy
Jan 10, 2006 06:41 PM
Vader
Oct 26, 2004 12:32 AM
