Atw or aeb
Old Jan 13, 2008 | 05:11 AM
marlonduval's Avatar
Member
Default Atw or aeb
What the difference and how do I kno wat I have
Old Jan 13, 2008 | 05:42 AM
CLX's Avatar
CLX
Zombie Defense Force
Default RE: Atw or aeb
It's stamped right on the head, and the ATW engine was in 2000+ 1.8T's, came with a bit more horsepower, internal water pump, and was DBW. Sadly, none of that is going to be able to help you create a coherent sentence.
Old Jan 13, 2008 | 12:03 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: CLX
wrong engins. The ATW was only in the 2000 and it the least desired engine. The AEB has a large port head and DBC and the ATW has a DBW, map sensorand small port head. Both use the same blocks. The AWM uses a differnt block with internal wp and comes with a wbo2 sensor and larger ecu memory.
Old Jan 13, 2008 | 02:09 PM
Bogie's Avatar
so with an ATW engine, I could make how much more (%)HP with an AEB cylinder head than the ATW head?
Old Jan 13, 2008 | 02:11 PM
cincyTT's Avatar
I'm make believe
it all depends on the previous hp. Most with a ~400fwhp see another 25whp give or take just about the entire boost curve.
Old Jan 13, 2008 | 02:14 PM
Bogie's Avatar
So that's about 6% for a FWD, so I'm guessing 3-4% hp increase on a quattro then.
Old Jan 13, 2008 | 02:25 PM
cincyTT's Avatar
I'm make believe
there abouts. Not sure how well the % would hold throughout the hp levels.
