Back flushing oil lines? 1.8t
Old Feb 14, 2006 | 08:41 PM
gregp1962's Avatar
Default Back flushing oil lines? 1.8t
I'll be startring the engine after a turbo replacement. I know to crank it for a while to get oil into the turbo. But, I'm concerned about the oil pickup line from the pump into the oil pan. Is there a way to make sure that line is clear and not plugged up. I can't really see any sludge looking into the oil drain hole on the bottom. What ways do we have to chack and clean the oil system without taking the pan off? If I take off the oil pump, can I flush oil down into the pan from there? Just a thought.
Does anyone have a good diagram of the oil flow?
Old Feb 14, 2006 | 08:52 PM
techbod's Avatar
Default RE: Back flushing oil lines? 1.8t
only sure way is to take the oil pan off because the pick up pipe is also a filter
Old Feb 14, 2006 | 08:59 PM
gregp1962's Avatar
Can you see the pick up line from the oil drain hole?
Old Feb 14, 2006 | 09:06 PM
kakarot's Avatar
I think you can do seafoam too
ECS Tuning
B7 Models
Sep 5, 2012 04:22 PM
ECS Tuning
Sep 5, 2012 04:21 PM
ECS Tuning
Sep 5, 2012 04:19 PM
ECS Tuning
Sep 5, 2012 04:17 PM
ECS Tuning
Aug 29, 2012 03:15 PM
