battery keeps getting drain "test" question
ive been having problems where the battery keep getting drain. Ive heard, to test where the drainage is coming from you hook up a volt meter to the postive battery side and ground the the other wire. Then you start pulling one fuse at a time to check to see if the voltage drops. which ever fuse you pull and the volt drops the most that is the source of the drainage problem. true or not?
NOTE: the after market system is not hooked up.
RE: battery keeps getting drain "test" question
ORIGINAL: ek4__
Have you had the battery and alternator tested? Most major auto parts stores will do it for free.
So when the cars off and all accessories off. get a test light and unhook your battery ground cable. Hook up the ground on the test light to the ground cable and then the psotive of the light to the positive cable thats still attached to the battery. If this lights, then theres something draining it. You have to keep the light on there in place and pull each fuse out one by one, then place it back in,waiting for the light to go out. When you pull a fuse and the light goes out this would mean that one of the particular things on that fuse is draining your battery. Worked for me on my 87 Audi, cant see it not working for you. Give it a shot and someone correct me if those steps are wrong.
ok ive been doing some research myself and i found this post in some other forums. thanks for the feedback and help.
ORIGINAL: ek4__
So when the cars off and all accessories off. get a test light and unhook your battery ground cable. Hook up the ground on the test light to the ground cable and then the psotive of the light to the positive cable thats still attached to the battery. If this lights, then theres something draining it. You have to keep the light on there in place and pull each fuse out one by one, then place it back in, waiting for the light to go out. When you pull a fuse and the light goes out this would mean that one of the particular things on that fuse is draining your battery. Worked for me on my 87 Audi, cant see it not working for you. Give it a shot and someone correct me if those steps are wrong.
I have a with the battery which is about 1 year old. I should note right off the bat that I usually only drive my car on weekends so that might be the problem, though it's been like that for about 4 months and only now am I having an issue. but up coming days have plan to ride regular basis.....
