BBK on 17's
Old Nov 13, 2007 | 06:00 PM
Dj Spiel's Avatar
Default BBK on 17's
Is anyone running Big Brake Bit on 17 inch wheels? (without spacers)
I can't see myself gettingn wheels that are 18inch Audis weigh enough I dont see myself goign 18inch
Old Nov 13, 2007 | 06:03 PM
cincyTT's Avatar
I'm make believe
Default RE: BBK on 17's
Depending on the Kit, if they are 332mm/13.1 or smaller they should fit.
Old Nov 13, 2007 | 06:07 PM
Dj Spiel's Avatar
Thats stage 1 i think....
How big are Porche ones
Old Nov 13, 2007 | 06:22 PM
cincyTT's Avatar
I'm make believe
Stg 3 and down are 12.6" - 12.1"
With tt carriersstocks go to 13.1"/328mm
Old Nov 13, 2007 | 06:27 PM
PandaXpress's Avatar
it depends on the style and off set of your wheels also
u have to worry about the rotors AND CALIPERS
most 17s will probly clear 312mm
and they might not clear 332mm dependin on the wheel
but most cheap wheels wont clear brembo/Porsche calipers
Old Nov 13, 2007 | 06:32 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: PandaXpress
dont know where cost of the wheels comes into play. 17's will fit the 13/328mm rotors, thecaliper depends on the offset of the wheel if you will need spacers, not cost. If you findwheels with a simular offest as stock you will be fine in most cases.
Old Nov 13, 2007 | 06:38 PM
offset doesnt always mean it will clear
Old Nov 13, 2007 | 06:39 PM
cincyTT's Avatar
I'm make believe
true, but its a good place to start.
Old Nov 13, 2007 | 06:43 PM
what wheels u got or getting Dj Spiel
Old Nov 13, 2007 | 07:47 PM
pyropenguin's Avatar
That one guy with the black B5 with SSR comps has an Alcon BBK w/ the 17" wheels.
(No, I'm not stalking him, I just love his car!)
