bent turbo fin (prop)
Old Jan 29, 2008 | 01:47 PM
whitejeepXJ's Avatar
Default bent turbo fin (prop)
Has anyone ever bent the fin back to normal on a K04/K03 or any turbo actually?
I have a slight turbo whine due to a bent fin (prop) in the intake side of the turbo and the turbo is only 10 months old (nope, no warranty!) and I was told I could just bend the fin back to normal and it would stop whinning.. if I could do this it would be awesome!!!
Thanks,
Mike
Old Jan 29, 2008 | 01:52 PM
ThePapaCMan's Avatar
Default RE: bent turbo fin (prop)
eh, I suppose in theory you could do it, but it sounds like risky business to me. If you don't have the money for a new turbo you could always rebuild it.
Old Jan 29, 2008 | 02:11 PM
powersmokin's Avatar
no you cant because the turbo will not be balanced and it will wear out the bearings in the turbo then the turbine will hit the housing and then lock up or blow apart and cause more damage then its worth.
Old Jan 29, 2008 | 03:38 PM
Papachristou's Avatar
Do you have any idea how fast turbos spin? i dont but i know its ******* fast as hell... 50,000rpm or more probably... at any rate whatever it is, this isnt a radiator fan on a chevy truck you can just bend back to place... get it rebuilt or buy a used one...$200-300 bucks probably
Old Jan 29, 2008 | 03:47 PM
CLX's Avatar
CLX
Zombie Defense Force
Not to mention that if you stress the metal fin any, it will weaken. Then add spinning at such a high rate of speed generating pressure, that's a huge amount of stress.
Old Jan 29, 2008 | 04:29 PM
good point, i know several times i have tried to straighten slightly bent metal on sunglasses or various things only to have to break off when it was almost straight again.. and those kind of parts arent under incredible centrifugal force!
Old Jan 29, 2008 | 06:38 PM
TorsenTaxi's Avatar
If you could bend it, how much would you bend it? Even if you were to get the dimensional issues acceptable, turbos are a centrifugal compressor with fluid dynamics, rotational dynamics, and the extreme rotational speeds (100,000 rpm is not uncommon) can result in a hand grenade if they fail at full power. You can have it repaired as most compressor disks are bolted on whereas the turbine is not.
Recommend that you keep your foot out of it until it is repaired properly, by a shop that is familiar with turbochargers. Replacing a turbo is a driveway possible job, rebuilding a turbo requires the shop, the tools and the knowledge.
Old Jan 29, 2008 | 11:29 PM
01AudiA4's Avatar
Dont even be thinking about bending it. Just replace or rebuild. Don't go cheap.
Old Jan 30, 2008 | 12:05 AM
hiwords's Avatar
would you balance your own wheel without a balancer machine? i'm just using an analogy but it is your car lol.
Old Jan 30, 2008 | 08:36 AM
10-4 guys thanks for a info.. going to be keeping my foot off the pedal until the new or used turbo comes in...
richorrell
Nov 15, 2013 12:51 AM
ianmark
May 23, 2011 04:03 PM
shane.trammell
Mar 18, 2009 12:49 AM
headshok2002
Nov 15, 2008 11:32 AM
apg96
Apr 4, 2006 12:30 AM
