Which is The Best Diverter Valve - Help Me
hey guys u probably heard this one before but since most of you have it on your car, i was just wondering which is the best diverter valve.
i have an B6 1.8 quattro, my car is going into the shop on thursday (for: CAT, STARTER, FUEL PUMP, GAS FILTER, CLUTCH SWITCH etc. not bad all at once hahahahahhaha about 2 grand lol)
anyways back to the subject i wanted to get an diverter valve so the sound will be a little better, my car is pretty stock, i have an intake from CARBONIO,you can hear it a little bit, but i heard its bettersoundewitha diverter valve
So which one should i get ???
Thank You
Thank You
Why STARTER and FUEL PUMP?? normally they don’t go bad. or is it one of those games “what doesnt belong here"�
as to DV you should use a search at the bottom of the page it’s been covered MANY-MANY times.
please use the search button... you should probably chip your car as well... you have an B6 some of that stuff isnt needed (depending on milage)... forge is a great DV, it all depends on how much your willing the spend, can range from 50-180...
please use the search button, or else prepare yourself for some flaming...
Should be going into the shop for this stuff instead....
Chip
DV
test pipe (or high flow cat)
exhaust
All forwell under 2grand. (probably 1700)
Not sure why you are replacing the fuel pump, starter, clutch switch, and filter. They usually last a lot longer, unless you have like 150k on your car or something.
Chip
DV
exhaust
WELL as for my car, i special ordered it, and now it hav about 110,000 on it
for the starter - my car won't start anymore
fuel pump - i hear a noice when i start the car and sometimes when i drive when accelerating
cat - emission
clutch switch - check engine light code
fuel filter - well since i got so many miles i thought it was time since audi service probably never replaced it
and i was about to do upgrades till few days ago i realized i got these problems [:@]
cat - emission
Lol, car not starting could be a problem.
Since you are replacing the cat anyway, replace it with a high flow, it doesnt cost any more. At least you'll get one upgrade out of the deal!
well the only high flow i found was from MILLTEK, which ran about for $990 which i think its crazy, and the guy told me since i dont have any upgrades it don't pay out to pu it on
I have a bailey's dv on my B6 and have loved it from day one. It performs great! gives off maybe a little more sound than stock but then again sound wasn't what I was going for. I wanted something to perform well with my car.
