Best Shifter?
Old May 17, 2005 | 06:04 PM
Rush4theYehO's Avatar
Default Best Shifter?
From what I've tried, Audi manual transmissions are not a pleasure to row through. They're mediocre at best. What is the best aftermarket shifter? I hear that B&N is too short for daily driving. I'm lookin for something that shifts precisely yet isn't so short you hardly feel yourself rowing through gears. What works for you guys?
Old May 17, 2005 | 06:07 PM
brrman's Avatar
Default RE: Best Shifter?
DIY
Old May 17, 2005 | 06:13 PM
DIY = do it yourself?
Old May 17, 2005 | 06:16 PM
BFlan2001's Avatar
correct, diy...you can also buy the cheap ones off ebay, they're much cheaper and i have yet to hear any complaints about them....aside from occasionally having to drill out the holes a little
Old May 17, 2005 | 06:25 PM
audihere's Avatar
Banned
yes drilling out the holes and i had to grind the ball down to get the ring to fit to hold the ball in place. other than that i love it and it is also adjustable to where you want it.
Old May 18, 2005 | 02:15 PM
I have a problem though. I'm not very mechanically inclined, and I'm lousy at these kinda projects. How much time/effort/money would it take?
Old May 18, 2005 | 03:12 PM
brrman's Avatar
the DIY mod takes no money.
You basically remove the shift lever, cut off a part of the lever rod, drill a couple holes lower in the fulcrum, use that new hole as the pivot and put back in car. The hardest part is putting it back in the car - its a real PITA. No special tools or anything are needed (except a tap/die which is not really all that expensive).
Audiworld tech article - DIY Short Shifter
Old May 18, 2005 | 10:29 PM
a4fanatic82's Avatar
whats wrong with shifting being too short? It makes it easier
Old May 19, 2005 | 04:39 AM
brrman's Avatar
ORIGINAL: a4fanatic82
what? what are you talking about, man? The point of the DIY is to shorten the shift.
But no - the short shift actually makes shifting harder and more stiff, not easier.
Think about your physics. Shorten the lever and you need to apply more pressure to move the counterweight.
But the shift is quicker - and thats what people want.
Old May 19, 2005 | 11:04 AM
audiboy1618's Avatar
I spent the cash on a b&m, works extremely well,
