Bleeding coolant system
No, I don't have a VAG COM. I KNOW I need to get one. I don't have a CEL. Could there be codes without a CEL?
About a month ago, I put in a new coolant temp sensor and had to refill the coolant. That's really all the work I've done that would affect coolant. I've never heard of bleeding a coolant system. (You don't have to do that on NORMAL cars) How do you do it?
CEL codes usually only relate to the engine or emmissions. You may find all kinds of fault codes without a CEL.
What do you mean you don't have to bleed normal cars?!!!
I didn't have problems with mine when I changed my water pump.
There is a bleed hole on top of the heater hose:
http://forums.audiworld.com/a4/msgs/1694837.phtml
http://forums.audiworld.com/a4/msgs/1472390.phtml
http://forums.audiworld.com/a4/msgs/1694969.phtml
yah just loosen the hose at the heater core and pull it out till you can see through the little hole in the top run the car with heater on till coolent comes out... on the 1.8T that is on the 2.8 it sugest bleeding it at the pump to...
OK, I bled it at the heater coolant hose as suggested. I couldn't see that any air came out though. Coolant came out almost immediatly. It still blows barely warm air. A little cool. Should I let coolant run out the little hose for a while? It seems to me that any air would be the first to come out.
BTW, what coolant do you all use?
All I can think is a clogged/bum heater core.
There are 2 rubber pipes running from the engine bay into the cabin (attach to the "nipples" of the heater core), to the driver's side of the battery. Clamp the one on the driver's side so that your coolant doesn't go everywhere. Take an air hose , and while covering the outlet to the heater core, blow it out. If the air flows through, it's not clogged.
How are your engine temperatures after the car is warmed up?
