AudiForums.com
-   Audi A4 (https://www.audiforums.com/forum/audi-a4-8/)
-   -   Blower Motor - Found The Problem (https://www.audiforums.com/forum/audi-a4-8/blower-motor-found-problem-46822/)
leander Nov 17, 2006 05:14 PM
My blower motor hasn't been blowing, managed to get to it via the pollen filter end. When I've turned the fan on it doesn't turn but when I nudge the blades off it goes spining and turning. I've sprayed WD40 to try and loosen it up. Once its running its okay but when I turn it off and re-start it wont turn yntil its given some help. The mechanism feels smooth and it doesn't appear to be binding? Is it time to get a new motor?
wood_e Nov 17, 2006 05:34 PM
RE: Blower Motor - Found The Problem
Might be the connector?
akielb Nov 17, 2006 06:05 PM
[sm=bustedsign.gif]
wow your lucky - nobody has flamed you for opening a new post when you already had one open about the subject lol
first post YESTERDAY
I'm so glad my name doesn't say newbie anymore - This means I'm no expert but I do know how to read and search first.
And above all I know not to open a new post just to update a post I made the day before
[sm=badbadbad.gif][sm=badbadbad.gif][sm=badbadbad.gif][sm=badbadbad.gif]
[sm=guilty.gif]
[sm=shutup.gif]
ProOnThaSnow Nov 17, 2006 06:14 PM
^^^^^ NOOBIE!!!! ^^^^^
haha, like I have much room to talk, I've got more posts, but you've been around longer! And as far as the Blower motor goes, thats rather wierd. How hard is it to pull out? If it isn't too bad, I'd maybe pull it out, rip it apart, and rebuild it, if at all possible. Maybe it'd work then.
leander Nov 17, 2006 06:39 PM
Thanks for your worthwhile response. Correct, I am a 'newbie' and yes I'm still getting used to using the forum. I'll take onboard the point you make but at the same time I'll ditch the sarcasm that surrounded your point.
ProOnThaSnow Nov 17, 2006 09:14 PM
In all honesty, I wasn't being sarcastic, I really would rip it apart, reassemble, and see if it works. sometimes it helps.
david9999 Nov 18, 2006 10:14 AM
If nothing is binding, then it is likely that the motor is weak.
leander Nov 18, 2006 05:59 PM
tHANKS FOR ALL OF YOUR HELP, IT WAS MUCH APPRECIATED. I PROMISE TO USE THE FORUM BETTER (I'M STILL GETTING USED TO IT), THANKS AGAIN.
