boost after FMIC install
Old Sep 10, 2006 | 03:45 AM
SilverPullit's Avatar
Default boost after FMIC install
just installed my racetec FMIC. before FMIC boost was 17-18 psi each gear. after the FMIC install 1st and 2nd are about 15 psi and 3rd 4th 5th are all 17-18 is this supposed to happen. i know there is a very small psi drop accross the FMIC but i didnt expect it to afect 1st and 2nd. any input is appreciated. thanks.
Old Sep 10, 2006 | 03:48 AM
BadLuckAudi's Avatar
Default RE: boost after FMIC install
Id check for a boost leak in your system, with my intercooler install i saw less than .5psi drop
Old Sep 10, 2006 | 04:23 AM
ADubyaD's Avatar
SoCal Crew Member
did you get a good amount of power out of the intercooler? think it was worth it
Old Sep 10, 2006 | 04:39 AM
mine was well worth it I loved how much longer and harder it would pull
ORIGINAL: ADubyaD
Old Sep 10, 2006 | 05:00 AM
BaconBait's Avatar
ORIGINAL: SilverPullit
It's intercooler pressure drop. For a scientific explanation scroll halfway down this page to the section titled "Pressure Drop."
What boost controller are you using?
Old Sep 10, 2006 | 05:09 AM
yea but it really shouldnt be that much, especially on a nice name brand Ic like that.... i mean .5psi is at the upper end of the ammount you should be loosing
ORIGINAL: BaconBait
Old Sep 10, 2006 | 12:16 PM
david9999's Avatar
I think you got some bad psi readings. As the engine speed is the same in 1 and 2 ans 3 and 4, the same amount of air is being pushed in each gear.
Old Sep 10, 2006 | 01:38 PM
tatman9999's Avatar
I have a forge fmic i was boosting 20 psi before the fmic.After i was boosting 18psi.I changed the n75c valve to a n75h and im boosting20psi all gears all the time.
Old Sep 10, 2006 | 04:47 PM
quattrosedan's Avatar
When I did my fmic, I didn't lose any boost at all. Just curious, you did use 2.5 inch piping or bigger, right?
Jaxspeeddemon originally had a fmic installed with 2.1inch piping and he lost about 8psi in every gear, from 25 to about 17psi.
kwik_shift
Jul 9, 2008 06:29 PM
compmanben
Apr 6, 2008 09:23 AM
compmanben
p1zl3
Jul 4, 2007 09:31 AM
BadLuckAudi
Feb 12, 2006 09:51 PM
