boost gauge wiring ?? Boost Gauge installed..
So as I wait to find out whats wrong with my car (limp mode no shifting tranny issue)
I decided to finally install my boost gauge ..I got it off of another member who diy center vent
anyway no problems running the vac lines (I ran it to the FPR line ..think thats the best)
but couldnt get power to run to the light in the gauge?? posted is a pic of the rear... I hooked up wires into clamps cliped them onto the rear prongs then ran them to AWE instructions say for their gauge .. no power??
Electronics have never been my thing..Im more mechanically inclined...
anyone??
[IMG]local://upfiles/2958/146FADDF99A241CAB811FE2DE05A2372.jpg[/IMG]
anyone??
tap into the wires off the vent lights use this to help
http://forums.vwvortex.com/zerothread?id=2365126
you will need to get connectors unless he gave them to you with the guage, auto parts store like a couple of bucks, roll of wire same, or i would use 2 rolls, just to be safe
gotcha ..thanks for the link ...but take a look at the back of my gauge..see the prongs coming from the back ? which is pos and which is neg?
thats whats not explained in the post about the diy ...again electronics arent my strong point but I have those metal slip on clips and copper wire that has two wires on it.. how do I go from here??
sorry if I sound electro = stupid..lol
Thanks alot
TS
Thanks alot
TS
It doesnt matter what side is pos. and neg.,
what i did was get some cheap wire, link one wire from one prong to the 75X terminal and another wire from the other prong to a dead screw or something. that is all
O and check to see if the light bulb is not dead, i had that problem, go to kragen or someplace and and get a new bulb
no pictures, sorry
no pictures, sorry
I thought I wouldnt matter..so I tried both ...still no juice...
Im thinking that its probably a dead bulb.. how do I remove it and what color size bulb should I get ...its a vdo gauge suppose to match the interior
thanks alot
thanks alot
Your gauge looks a lot like mine
and on mine, to get the light out is kind of a pain in the A**, but i got a wrench and grabed it and yanked it out. You can see on the plastic light housing that the outside edge has 4 "bumps". you pinch those in. imagine like getting a dvd outof a dvd case i guess. I cant really explain it. just give it a good squeeze and pull. No punn intended.
About the light. I dont remember what # or brandthe light was but if you go to kragen, they should have a ton of little lights that look exactally like like your light. Im pretty sure it doesnt matter which one you get as long as its the right ammount of wattage and voltge. I think it was something like 4 wats and 12 volts? On my bulb that came with the gauge, the voltage and wattage was printed on the bulb itself, so your might say also. they all come in one color unless you specify the color like red or blue. your bulb is probalby a white yellow-ish bulb
good luck
good luck
great!! thanks for the tips for "giving it a good squeeze and pull." haha
wish I woulda left itwired up (exactly like you had.. 75X andbolt atop the fuse box) but I removed them and bolted up the kick pannel.. ahh double work gotta love it
thanks!!
thanks!!
