boost question?
I finally got my car running well again.. Took out the 007 dv and put in a 710n, relized i was over
Tightening the 007 and it was not working properly (my friend justing pointed that out) any way i left the 710n in there untill I get a different DV, not a big fan of all the springs..
ok so here is the question, I have replaced alot of the vacum lines so i dont think i have a leak anywhere, Im holding 19psi which is what i should be holding, I spike to 21 or 22.. sometimes the needle on the boost gauge like vibrates up and down between 17-18 or 19psi really really fast, you cant feel any power flucuation just see it in the needle.. only happens once in a while.. what is that? and should i worry about it..
yea once in a while i get a rough idle.. I think its really caused by switching back and forth between programs on the ECU, i have noticed if I do a throtle body adustment after i switch programs my idle is fine..
I was told its the injectors, I have bosch 440cc injectors and the ECU was tuned for Delphi 440cc injectors.. dont know why it makes a difference but it dose.. every question will really be answered when i rebuild the motor, still need to do the leakdown but the only thing that is going to do is make me angry...
interesting.. ya my clutch is ok but i cant do launches dont trust it, you can feel it chatter a bit, cant wait to rip the car apart and install a new one..
I do have a new camera... i think i might be able to do something if someone showed me how to upload the video
