Break Squeak
Old Apr 28, 2005 | 11:24 PM
apg96's Avatar
Default Break Squeak
My brakes have started to squeak but not all the time. They only squeal after the car has gotten warm and has gotten some good stops in. They only squeal at low speed stops liek at the end part of stopping at a red light. (like 20-0 mph). Is this just like normal brake squeaks or is it something differnet? Should i look into some new brake pads? i have 78,000 mi.
Old Apr 28, 2005 | 11:26 PM
Jestnomen's Avatar
6th Gear
Default RE: Break Squeak
Well take a flashlight and examine your pad thickness. If it is very thin, then your brakepads are wearing out. If you don't know what worn brake pads look like then you should probably schedule an appointment to have them checked.
Old Apr 28, 2005 | 11:35 PM
BFlan2001's Avatar
most brake shops will give you a free brake inspection....but try to sound like you know what youre talking about or they'll scam you into all kinds of unnecessary maintenance...
Old Apr 28, 2005 | 11:44 PM
apg96's Avatar
do u guys have a thickness. I know how to check brake pads just i haven't seen alot of worn out pads i usually measure them.
Old Apr 28, 2005 | 11:52 PM
Jestnomen's Avatar
6th Gear
no just eyeball it. You know the part of the pad that actually makes contact? If it's below 1/4-1.8" then they need replaced. If your brakes are squeeking then you can almost bank that they are worn anyways.
Old Apr 29, 2005 | 01:28 AM
PandaXpress's Avatar
here a pic
OK PADS
THINNING PADS
kwarr1987
Aug 25, 2014 03:38 AM
Pjbrof
Aug 5, 2009 11:44 PM
ron86toy
Jun 4, 2009 05:14 PM
marcb0127t
Feb 7, 2009 07:55 PM
klb3284
Mar 29, 2006 10:16 PM
