Bunch of CEL codes. P0411 + P1128 + P0300 + P0303 + P0304/
Old Mar 30, 2007 | 08:45 PM
traian2003's Avatar
Default Bunch of CEL codes. P0411 + P1128 + P0300 + P0303 + P0304/
I just took my car to the mechanic and i made him read a code that was there about 3 months ago. To my surprise there were a lot more... It's an AUDI A4 1.8T Quatro. It's a 1999.5 with 180km on it.
These are the codes listed:
P0411 - Secondary Air Injection System (B2) - Incorrect Flow B
- I have no idea to even know what to look for in order to fix this.
P1128 - Long Term Fuel Trim - System too Lean (Bank 1) B
Try1: I understand that I would have to look for any leaks in the vaccum hoses.
Try2: Clean the air filter
Try3: Replace MAF.
Try?: Any other ideas?
P0300 -Random Misfire Detected - Any Cylinder B
Try1: Replace all the spark plugs
Try?: What else should I look for?
P0303/P0304 - Cylinder #3 - Misfire Detected A or B / Blink- Cylinder #4 - Misfire Detected A or B / Blink
Try1: Hope the above to fix this too.
Any help will be much appreciated.
Old Mar 30, 2007 | 08:55 PM
Audi_Skydiver's Avatar
Default RE: Bunch of CEL codes. P0411 + P1128 + P0300 + P0303 + P0304/
For the misfire try changing/switching the coil packs around. If it follows the coilpack then you need new ones.
Josh
Old Mar 30, 2007 | 09:05 PM
traian2003's Avatar
For the P0411 code i'm thinking of trying this, anyone ever tried this method?
http://forums.fourtitude.com/zerothread?id=1995162
It seems that the hose is being flattened, so I'm thinking about replacing it just like in the pictures. Any one else have any ideas why this should/should not fix it?
wenglish
Mar 31, 2012 09:44 AM
chongboi
Apr 26, 2010 07:09 PM
CALI KID
Sep 23, 2008 03:20 PM
