camber
Old Feb 1, 2007 | 06:58 PM
ugadawg24's Avatar
Default RE: camber
ORIGINAL: insuite
the stock sport package (if you have it) has enough camber adjustment to deal with the lower ride height. you must however (as brrman suggests) get an alignment if you lower the car.
So I just brought my '03 A4 (stock sport package) in for an alignment. On the front right, the toe was at -0.04 and was adjusted to 0.18 (spec range is 0.08 to 0.25). The camber was at -1.3 (spec range is -1.2 to -0.4). However I was told that camber is not adjustable on the car.
The reason I brought it in for alignment was that I noticed wear on the inside of my front-right tire upon rotating them. Could the toe adjustment have fixed the wear problem? Or should I be concerned with the camber being slightly out of spec?
DEjunkie
Jun 8, 2008 10:06 AM
theTTkid
May 25, 2008 02:47 PM
mypreludeisred
Jun 24, 2006 05:04 AM
lyl
May 3, 2006 04:45 PM
japchef
Oct 22, 2004 03:52 AM
