Can you attach your ground wire to the bolt holding the stock amp?
I'm installing my subs and I need to know if it is safe to use the bolt holding the bracket holding my stock amp for the ground. I was afraid any current running through the ground would mess up my stock amp. Thanks for the help
I couldnt find another bolt that i could unscrew all the way and put back in. the amp kit i have requires you to take the whole screw out, place the circle ground wire thing on the screw, and then screw it back in
ORIGINAL: banderson121
oh you attatched it to the stock amp bracket bolt and it didnt mess it up at all?
Josh
I used a bolt that attaches the carpet wall in the trunk to the baffle board. I used it because i mounted the amp on the baffle board. If there is a bolt that you would really like to use but cant remove it, you can always mod the wire ring or pick-up a open endconector.
