Can't remove factory radio
Old Nov 7, 2006 | 06:15 PM
smokeU's Avatar
Default RE: Can't remove factory radio
when you had it out did you look at the sides? like what exactly is holding it in there? theres a clip in there and when you put the key in the slot it retracts the clip. but you can put something in the side and compress the clip. its risky but if you have no other choice just force it out. it will break the clip but thats ok you can make it fit snug again easily. good luck. and dont hurt yourself.
Old Nov 7, 2006 | 06:18 PM
BadLuckAudi's Avatar
yes yes, glad your still promoting the right way to do it, lol all these jackasses that use high to low converters dont know what good bass sounds like till you do it right !!!
and as far as removing the radio my method worked pretty well every time..... stick fingers in tape hold grab on and pull really hard worked every time
ORIGINAL: onepoint8tee
ORIGINAL: aRIf
Jason,
is there a place to connect amp on our stereo ?
You can hook up female RCA's to any stereo for a preamp output. Just a matter of splicing.
coolvirus:The tool the dealer uses is like $50 and i didnt buy it. I never ended up having luck with the keys i bought so i just said F it. I thought i had my wiring messed up but it turned out to be a bad ground for the amp hooked up in the trunk.
Old Nov 7, 2006 | 06:30 PM
onepoint8tee's Avatar
ORIGINAL: BadLuckAudi
haha... Straight from the Bently Manual huh?
I dont think that method would work well with a dual din symphony radio though... Or is that what you had?
Old Nov 7, 2006 | 06:33 PM
coolvirus's Avatar
Yes, I saw the clip when I removed the radio a few months ago. I'm not sure what I can put in the side to compress the clip. It has to be something very, very thin.
BTW, can you really remove the radio by just pulling hard on the tape deck?
Old Nov 7, 2006 | 06:36 PM
ORIGINAL: coolvirus
I dont know but if badluckaudi says it can be done, it probably can. I tried on mine with no luck, but i didnt want to rip off the radio faceplate or crack it so i didnt pull with full force. Mine is the symphony radio though.. I dont know about the single din concert radios.
Old Nov 7, 2006 | 06:46 PM
coolvirus's Avatar
I'm afraid to try.
Old Nov 7, 2006 | 06:48 PM
techbod's Avatar
dangerous to say the least because of damage, check that link out there are some good tips on there
Old Nov 7, 2006 | 06:53 PM
  #18
techbod's Avatar
im thinking badluckaudi means ( insert the removal keys then use the cassette aperture to pull the radio out ) or at least im hoping so
Old Nov 7, 2006 | 06:57 PM
  #19
lol if by removal keys you mean fingers in the tape slot then yes, lol....... I wasnt too worried about breaking it, and i guess it didnt break it so all is good.... I had the Bose one though so i dont know about the symphony
ORIGINAL: avant80@2.6
Old Nov 7, 2006 | 06:59 PM
  #20
coolvirus's Avatar
avant, I checked out the link but it's just a bunch of images of radio removal tools. I don't know if I'm looking at the wrong thing.
