car-lighter problem
Old Feb 22, 2007 | 04:04 PM
twistedA4's Avatar
Default car-lighter problem
i have a 1999.5 Audi A4 1.8T-- and the lighter slot doesnt pop up!.. how can i fix this problem? or get the lighter slot to pop up?
thanks,
shawn
Old Feb 22, 2007 | 08:53 PM
jbracci's Avatar
Default RE: car-lighter problem
blown fuse my is that way the fuse pannel is on the driver side dash when u open the door need a little screw driver to get it to pop out then the labble is their and in your owners manual
Old Feb 22, 2007 | 10:02 PM
cstarky15's Avatar
is it the lighter or the slot that holds the lighter? if its the slot which i think it is then i think you might have to pry it up. becareful. if it is just the lighter not popping up then it is a sign for you to stop smoking.
Old Feb 22, 2007 | 10:53 PM
Boostfed13's Avatar
I had the same problem I just pried on it with a butter knife and it poped up the reason is the lighter its self was not fully seated in the socked so it sticks out and prevents it from flipping up.
Old Feb 22, 2007 | 11:28 PM
speedracer52's Avatar
My lighter wont stay down. Any ideas?
Old Feb 23, 2007 | 12:02 AM
Boostfed13's Avatar
Get a new lighter there cheap.
Old Feb 23, 2007 | 03:17 AM
qUaTtRoA4's Avatar
when I first got the car the lighter wouldn't stay down, so I bought a new one and this one doesn't stay down either, oh well
Old Feb 23, 2007 | 04:29 AM
cstarky15's Avatar
yeah that sucks it wont stay down but be happy that is the only problems you are having.
Old Feb 23, 2007 | 04:35 AM
qUaTtRoA4's Avatar
^+1-damn! you've got me knocking on wood!...
Old Feb 23, 2007 | 06:23 PM
acetrebo's Avatar
Mine had the same probelm, pulledthe housingout and found it was not connected, which is why it did not heat up and pop out.
God knows what they did with the wiring, must have used it for a turbo timer or something that they removed before they sold it.
I quit smoking 2 years ago, so I put it back in, and left it.
Check the fuse first, if that is good, pull out the housing and make sure its wired.
robclarke6
Sep 7, 2012 06:57 AM
stuck amals
Sep 25, 2011 04:13 AM
rambo82i
Oct 22, 2007 03:02 PM
thekyman
Jan 18, 2007 06:47 AM
