CAR LOST POWER, CEL WENT ON AND MADE REALLY LOUD TICKING FROM ENGINE....PLEASE HELP =*(
Old Sep 7, 2006 | 09:53 AM
techbod's Avatar
Default RE: updates....
im sure that's the MAF sensor it goes into the top of the airbox no wonder it wont start
edit - I could be wrong though but its definitely a metering division of some sort
Old Sep 7, 2006 | 12:26 PM
itsjappo's Avatar
do you see that vacuum valve that burnt out and I had to cut it off and install new hoses and T fittings on to patch it up to drive home? I am wondering what that thing is and if that could cause my problems. Please see pictures for reference.
picture 1 and 2 is the actual valve with hoses connected to it where i cut it
picture 3 is where it used to be and how it was "patched" to get home
picture 4 is a comparison pic of where the valve use to be and how it was originally connected comparing next to the temporary fix that I did.
Thanks guys and please reply with ideas/suggestions.
Old Sep 7, 2006 | 12:28 PM
TomRitt's Avatar
Default RE: CAR LOST POWER, CEL WENT ON AND MADE REALLY LOUD TICKING FROM ENGINE....PLEASE HELP =*(
sounds like what happened to me when my crank gear sheered its keyway. timing belt slipped a couple teeth and the car lost power, then while crank to restart it, it must have slipped more and i heard a lotta ticking and thats when I knew what happened. Basically everything was destroyed, valves went through the top of the pistons
Old Sep 7, 2006 | 11:39 PM
itsjappo's Avatar
well was the car able to start after that happend? this item pictured is a purge valve correct guys? how much does it cost and where can i get it? please let me know...thanks. i will try to replace that and see if any luck.
Old Sep 8, 2006 | 03:16 AM
acetrebo's Avatar
Sounds similar to when my timing belt tensioner broke.
The valve thing doesnt sound like your problem, but it wouldn't hurt ot replace it to rule it out, you should replace it anyway.
if the timing belt is loose (broken tensioner) it will slip, and eventually probably wont start once it is to far off.
Unfortunately, the only way to know for sure is take the car apart and get the t-belt covers off and inspect the timing belt and components.
how many miles on this, what year/ model is it?
Old Sep 8, 2006 | 03:58 AM
itsjappo's Avatar
if the timing belt slipped...that means motor is bad b/c everything got all jacked up...i wil ltry to replace this valve if i figure out the name and where to get it....also..
the car is a 99 1.8t auto fwd ..135k
Old Sep 8, 2006 | 04:38 PM
itsjappo's Avatar
anyone?
Old Sep 8, 2006 | 04:54 PM
  #18
smokeU's Avatar
yeah if the belt slipped i'm pretty sure it causes internal damage. but I'm not the guy to be answering this.
Old Sep 8, 2006 | 05:00 PM
  #19
techbod's Avatar
compression test required, I wish you good luck
Old Sep 8, 2006 | 05:04 PM
  #20
techbod's Avatar
purge valve?? please confirm as its shown on picture #4 as intact where did it actually come from under the hood???
