AudiForums.com
-   Audi A4 (https://www.audiforums.com/forum/audi-a4-8/)
-   -   CEL:0170 (https://www.audiforums.com/forum/audi-a4-8/cel-0170-a-33410/)
forcefedaudi Jun 5, 2006 05:25 PM
CEL:0170
Any help would be apprecitated cel came on had it scanned Po0170 was the code that came up. find a broken vacum line replaced it but that didnt clear the code. Test pipe is in but did the no cel thing and that was installed awhile ago dont think it has anything to do with this. thanks
techbod Jun 5, 2006 05:47 PM
RE: CEL:0170
you sorted the problem but you need a diagnostic tool to clear the CEL
forcefedaudi Jun 5, 2006 09:04 PM
RE: CEL:0170
I replcaed the vacum line cleared the codes and then they came back yesterday
CRAZYHAWK Jun 5, 2006 09:22 PM
RE: CEL:0170
Fuel trim malfunction.
If not a vacuum leak, it could be the MAF.
forcefedaudi Jun 5, 2006 09:30 PM
RE: CEL:0170
How would i check the maf senser or should i just replcae it and hope
CRAZYHAWK Jun 6, 2006 12:00 PM
RE: CEL:0170
If you decide to replace the MAF, get a remanufactured one.
www.ecstuning.com
If you have more than 115K kilometers on the current one replace it.
techbod Jun 6, 2006 12:08 PM
RE: CEL:0170
how did you clear the codes??? just removing the ground wire doesnt clear the codes (it leaves soft codes in the memory) so when you start the engine pop you have the CEL again, there is a little cheat here remove the ground wire turn the ignition on and switch the headlights to full beam this depletes the computer of all power but has to be left for approx 20 minuets don't quote me on that Ive never done it on an Audi
forcefedaudi Jun 6, 2006 08:25 PM
RE: CEL:0170
i used snapons scan tool to read clear the codes. I dont have the proper programing to use the scanner as a trouble shooter.
techbod Jun 6, 2006 08:33 PM
RE: CEL:0170
snap on is a name only there are many on the market for a tenth the cost, if the code came back up what was it?? VAG software is no better at determining the fault, the code counts
forcefedaudi Jun 6, 2006 08:35 PM
RE: CEL:0170
sanpon is what my school carries its still the same code p0:0170
