CEL code help...
Old Jan 18, 2006 | 08:15 PM
ryanmcell's Avatar
Default CEL code help...
I had a CEL before and I fixed it and the check engine light went away. However it came back again even after fixing the problem.
Heres the code:
P0411
Secondary Air
Injection System
Incorrect Flow
Now before I had it checked the dealer told me it was one of the vaccum hoses, and vaccum jet pump.
Part #'s 06b133783bc and 058133753b were replaced.
However if the code came back up was this not the problem (even though the vaccuum hose was definately split down the middle)
Please help! Thanks in advance
Old Jan 18, 2006 | 10:15 PM
BFlan2001's Avatar
Default RE: CEL code help...
P0411 is probably the most common error code on audis, especially the 2.8s for some reason...how long ago was the repair done? most likely you have another crack in the hose
Old Jan 18, 2006 | 10:21 PM
dankhound's Avatar
What motor do you have? On the 2.8 there was a recall on the vacuum lines due to leakage. Youll also want to listen for your secondary air pump turning on. It draws air in thru the airbox, so you can follow the plastic pipe down to it if your unsure of location. You can also t a vacuum gauge into the vacuum lines after the solenoid to make sure the solenoid vavle is actually moving.
Old Jan 18, 2006 | 10:25 PM
ryanmcell's Avatar
i have the 1.8t i changed the hose not even a month ago. ive drove about 1000 miles since and it hasnt gone off until this afternoon....
Old Jan 19, 2006 | 01:06 AM
ryanmcell's Avatar
any other theories? does the P0411 just mean a vaccuum line?
Old Jan 19, 2006 | 12:21 PM
techbod's Avatar
air pump/valve/piping
A6 Quattro V6 30V
Aug 6, 2010 02:06 AM
snowman_w900
Apr 14, 2010 12:30 AM
pathak76
Dec 12, 2007 03:35 PM
MilitantGrunt
Nov 1, 2006 09:16 AM
tonym
Jun 14, 2006 03:49 AM
