CEL Indicated O2- turned off by itself ???
I just bought a '96 A4 Quat 2.8. When I got it the CEL light was on and the code indicated an O2 sensor. The first time I filled the tank (Chevron Plus) the CEL went off within 20 min. Should I be concerned about the O2 sensor? Could the gas have affected the reading?
I'll have to check what the exact reading was, but I know it was an O2 sensor. One of them was changed a year ago...does the code indicate which O2 sensor needs to be replaced? Does it make any difference that the CEL turned off?
Thanks for your help!
Usually I repalce the O2 sensors in pairs. When one fails the other probably isn't far behind.
The code will tell you which O2 it is. Also, jsut because the check engine light turned off doesn't mean the problem has been fixed. The CE light probably won't stay on indefinitely for a worn out O2 sensor because it is still switching, just slower than a new unit.
