changine oil
i need to change my 2.8 a4's oil, but I still need some info before i do it. What else needs to be changed, like filters, etc. it doesnt have to be related to changing the oil, but something that i should do while i am at it. And what kind of oil is the absolute best?
RE: changine oil
you might want to consider changing the cabin filter too. There is no "best" oil really. These are Audi approved:
1 Audi/VW Part number ZVW-352-540-S 5W-40 2 Castrol Castrol Syntec 5W-40 3 Chevron Chevron Supreme Synthetic 5W-40 4 Elf Elf Excellium LDX 5W-40 5 Kendall Kendall GT-1 Full Synthetic Motor Oil 5W-40 6 Mobil Mobil 1 0W-40 7 Motul Motul 8100 X-cess 5W-40 8 Pennzoil-Quaker state Pennzoil Synthetic European Formula 5W-40 9 Pennzoil-Quaker state Pennzoil Synthetic European Formula Ultra 5W-30 10 Pennzoil-Quaker state Quaker State Full Synthetic European Formula 5W-40 11 Pennzoil-Quaker state Quaker State Full Synthetic European Formula Ultra 5W-30 12 Seventysix lubricants 76 Pure Synthetic Motor Oil 5W-40 13 Texaco Havoline Synthetic 5W-40 14 Total Total Quartz 9000 5W-40 15 Valvoline Valvoline Synpower 5W-30 16 Valvoline Valvoline Synpower 5W-40 |
RE: changine oil
i hear mann is the best cabin filter, is this true?
RE: changine oil
yes it is the best oil filter too (it's oem).
RE: changine oil
whats the diff between the oil filter, and the cabin filter? are they easy to replace?
RE: changine oil
the oil filter filters the oil. The cabin filter filters the air before it enters the climate control system. Both are easy to replace if you've ever done an oil change before. The cabin filter is located on the passenger side behind the first firewall. Open the hood, look under the windshield. You will see a large plastic cover that goes under the windshield, remove the big black screws. It will pull out and you will see the place where the filter goes on the left. It's sort of a rectangle panel filter.
You may also want to change the engine air filter too. |
RE: changine oil
I know everyone says mann oil filter are the best, but i use a cold k&n filter, and my oil stays cooler, just something ive noticed..
RE: changine oil
when u change ur oil, u always change the oil filter, and check other fluids.
