Changing Vacumm Lines
Old Nov 21, 2005 | 09:07 AM
Dj Spiel's Avatar
Default Changing Vacumm Lines
I want to change vacumm lines out on 96 2.8L. How hard is it?
Old Nov 21, 2005 | 01:47 PM
hb972.8q's Avatar
Default RE: Changing Vacumm Lines
not hard. just buy about 3 feet of it and pull/cut off old one and replace with new one of equal legnth. i did them one by one so not to screw up.
Old Nov 21, 2005 | 01:53 PM
Dj Spiel's Avatar
Yes... but one line looks like it runs into dash board. Are they all accessible just from the top?
ORIGINAL: hb972.8q
Old Nov 21, 2005 | 01:58 PM
hb972.8q's Avatar
runs into dash board?? i did them like 2 years ago i just did all the ones i could see. never noticed one that enters the dash. i will have to take a second look
Old Nov 21, 2005 | 02:09 PM
Dj Spiel's Avatar
Ok Ill take pictures and post.
Old Nov 21, 2005 | 02:10 PM
Jestnomen's Avatar
6th Gear
You might consider buying some 3mm lines from a porche dealer if you have one near by. Their's are a lot more durable than the Audi braided ones. After 2 months the outside of mine were already cracking off.
Old Nov 21, 2005 | 02:14 PM
Dj Spiel's Avatar
http://www.autozone.com/servlet/UiBr...ESPE%7C%7Etrue
that ok?
ORIGINAL: Jestnomen
Old Nov 21, 2005 | 02:18 PM
Jestnomen's Avatar
6th Gear
No Audi stock vacuum hose is 3mm iirc, that is 6mm.
Old Nov 21, 2005 | 02:21 PM
Dj Spiel's Avatar
I can check to see if they have those in 3
Old Nov 21, 2005 | 02:25 PM
hb972.8q's Avatar
i replaced all the one in this clump[IMG][/IMG]
and one at the end of the green line under the ball thing[IMG][/IMG]
didn't see any that went into the dash board.
