Check engine light????
Old Oct 16, 2006 | 12:35 AM
acetrebo's Avatar
Default RE: Check engine light????
ORIGINAL: wood_e
Yeah, I say get the code first. If it points to the secondary injection pump then reset the ECU.
I disagree, he said the hose came off, that would probably throw a code. Pull the bat cable, if code comes back get it scanned.
Old Oct 16, 2006 | 12:52 AM
wood_e's Avatar
Yeah, if the hose CAME OFF and he has no OTHER DTCs he should just reset it if it's from the secondary air pump... if its another code he should investigate it.
Old Oct 16, 2006 | 01:00 AM
acetrebo's Avatar
It sounded like he didnt have a code reader. So, I just was saying, since his hose came off, that was probably the source of the code.
So, my logic is, that probably threw the code, so he could just reset it by pulling the cable. if it is something else, he should get it read ASAP as we all know.
I agree with you, I have a code reader, and that is always the first thing i would do, in this case I think he'll be ok unless the code comes right back, then it definitly needs further investigation.
So, see, we're both right!!!
Old Oct 16, 2006 | 01:04 AM
wood_e's Avatar
Yeah it's cool, we're on the same page. Pulling codes is simple and effectve, but the hose probably threw the code.
Old Oct 16, 2006 | 01:13 AM
acetrebo's Avatar
Well, its simple and effective, if you have a code reader!
ORIGINAL: wood_e
Old Oct 16, 2006 | 04:44 AM
CluTcH/B5's Avatar
wood_e and acetrebo
It made me laugh to read your conversation.
I'm going to do exactly what you guys said, first thing in the mourning.
Pull the damn batt cable if that doesn't clear the light, I'll have it scanned. If it throws a code I'll post it on the AF
Old Oct 16, 2006 | 06:01 AM
BadLuckAudi's Avatar
well good luck keep us posted
ORIGINAL: CluTcH/B5
wood_e and acetrebo
Old Oct 22, 2006 | 03:18 PM
  #18
Ponch's Avatar
check out http://www.steve-hall.com/cgi-bin/VAG-Locator.pl and look for someone in your area that has a VAG tool. You can pull the code to find out what caused it and clear it if you want.
Old Nov 5, 2006 | 08:50 PM
  #19
CluTcH/B5's Avatar
Well I forgot to repost after I un-hooked the battery. But that worked and the light hasn't came back on. I pretty sure I took care of the problem.
Old Nov 6, 2006 | 03:32 PM
  #20
acetrebo's Avatar
Another happy customer.
Glad that did it for you. See how easy that was?
have a good one!
parlayin
Feb 10, 2010 12:33 PM
MrTigz5254
Mar 7, 2008 11:56 PM
huyaroo
Sep 12, 2007 03:37 PM
blanthony
Mar 25, 2006 01:18 PM
