check engine light code P3081
My friend has a check engine light on his 03 1.8T GTI, it said something about air fuel metering. Does someone know what exactly is wrong? Thanks.
RE: check engine light code P3081
No one knows that code?
dont listen to me
i found this on another forum
19537 4C51 P3081 Engine temperature too low" That DTC is indicative of a missing thermostat, a stuck open thermostat, or a cooling system with 100% antifreeze. It is NOT associated with a defective ECT G62. |
good call i miss typed the code in[:@]
ORIGINAL: PandaXpress i found this on another forum 19537 4C51 P3081 Engine temperature too low" That DTC is indicative of a missing thermostat, a stuck open thermostat, or a cooling system with 100% antifreeze. It is NOT associated with a defective ECT G62. |
thanks!
