completly confused
Ok so i keep goin into limp mode. and im getting codes
17536- System Bank1, too lean and 17545- System Bank 1, Too Rich anyone have any idea how i'm running lean and rich at the same time.(and neither one is an old code cause i put everything back to stock and cleared all the codes yesterday and these 2 poped up today) |
RE: completly confused
bad sensor.
If your EBC isn't going haywire and your tuning software is working fine i would say its the upstream O2 sensor.
air vacuum leak
Damn dave that was deep.
i just changed my o2 sensor so it should be good, i put the n75 back in when i first got the lean codes and i've put it back to stock tunning. Hmmm... i guess i'll check for vac leaks
Clean your MAF while your at it.
did that yesterday too, would a bad map possibly cause these problems
Not likely, checking for vaccum leaks, and exhaust leaks are your best bet.
ok
