Compression test writeup
Old Nov 21, 2007 | 05:50 PM
khj677turbo's Avatar
Default Compression test writeup
Can someone give me the link? Cant find it in the search.
Old Nov 21, 2007 | 06:20 PM
Default RE: Compression test writeup
I searched diy, and tech section too, nothing. I must be retarded becasue i read the writeup a week or so ago. Can someone help me?
Old Nov 21, 2007 | 06:38 PM
aRIf's Avatar
I don't know if there is a write up but I did it a while ago,
-bought the tester from advance auto parts. I think I paid $30 or something;
engine should not be cold or hot. should be warm.
take out all the spark plugs and cables. unplug all the injector power connectors.
insert and secure the hose one of the spark plug's hole then attack the gauge then crank it 3-4 times. note it.
do it twice at least dont over crank it wait a while after each crank to keep the battery safe level.
factory numbers are between 147-191psi.
my numbers were; second test is in pharantesises.
| 0 | -> 175 (180)
| 0 | -> 166 (170)
| 0 | -> 164 (180)
| 0 | -> 159 (186)
easy to do, good luck
Old Nov 21, 2007 | 10:46 PM
Ok, i did it with my uncle, i had 180 on all the cylinders except the one close to the front of the car(cylinder 1 or 4?). I got 120 on that cylinder which confirms my guess that i have a bent valve. Thanks though arif, i found the writeup when i just searched compression lol oh well, sometimes the search button can be tricky.
Old Nov 21, 2007 | 10:53 PM
Bogie's Avatar
https://www.audiforums.com/m_689390/tm.htm
I had to look for it too...that was a while ago. How do think you bent a valve? Did the timing belt go on you?
Old Nov 21, 2007 | 11:15 PM
No, been battling locating this misfire problem for a while, and i didnt have enough time to deal with it being at school. So of course when i have time to fix it, the car misfires and isnt the same after. Now im taking it all apart with my uncle.
I was suggested that the car sucked a valve by my next door neighbor who is very very smart about engines, but he was just guessing, and ill take his guess till i find out for myself.
magicturtle2
May 9, 2014 10:32 PM
DOC_DEPALMA
Oct 4, 2011 06:33 PM
DSMKiller
May 7, 2009 06:36 PM
Dallas09
May 1, 2009 04:41 PM
wood_e
Nov 7, 2006 06:35 PM
