coolant issues
Old Jul 10, 2007 | 02:37 AM
scout98's Avatar
Default coolant issues
My car overheats when I am in traffic on hot days. Someone told me to check both my lower and uper radiator hoses and if one of them (in my case the bottom one) is somewhat cold or should I say not as hot as the other one that the thermostat is bad? I checked for leaks but nothing... So I think I'm going to replace the thermostat but I can't find a good writeup I have a 97 1.8T A4... Does this seem right? Also if anyone can direct me to a good write up I would really appreciate it... THANKS!
Old Jul 10, 2007 | 02:02 PM
scout98's Avatar
Default RE: coolant issues
bump
Old Jul 10, 2007 | 02:26 PM
Trey25's Avatar
the thermostat is near the water pump, which is behind the timing belt. This is a good write up... http://www.audiworld.com/tech/eng35.shtml
Old Jul 10, 2007 | 02:51 PM
rbrtech's Avatar
have you replaced the water pump before some of the fins may be broken not allowing proper circulation at idle. also may want to check the fanclutch. both of these can be effected at idle but work fine during acceleration.
numanamir
May 4, 2012 03:08 PM
Kpj
Aug 3, 2011 04:18 PM
tshay1
Jul 6, 2010 11:49 AM
kr1snarowsk1
Aug 1, 2009 10:05 AM
kaabee
Jul 12, 2009 04:29 PM
