Coolant/ Overheating Issue- Need help
Old Sep 19, 2005 | 12:58 AM
IgNuts's Avatar
Default RE: Coolant/ Overheating Issue- Need help
see the leak? around the black piece.
it's not leaking from here. Just dripping from above and coming down here.
Old Sep 19, 2005 | 05:00 AM
flyboy's Avatar
that pic is of the trans. but if its near the oil pan like you said, it may be the hose that goes to the coolant to oil heat extanger (fancy for oil cooler) I think you can replace both the hose and the cooler, not sure where to start looking.
Old Sep 24, 2005 | 01:13 PM
IgNuts's Avatar
I got the car checked out by a mechanic and he says there is a plastic flange that needs to be replaced. It is worn out and letting coolant pass through it.
Can somebody show me where it is in the engine, so I can change it by myself rather than pay him $200 to do this?
He said the platsic flange is in the back of the engine, where the coolant temperature sensor is. He says the plastic flange connects to a metal line afterwards.
Can anyone tell me the part number also? Thanks in advance!
Old Sep 24, 2005 | 03:02 PM
IgNuts's Avatar
I checked out the ECS Tuning website, and looked under the flanges section. The only flange there is the cylinder head cooling flange. Is this the flange I need?
vtraudt
Nov 11, 2013 01:24 AM
motorheaderr
Jun 17, 2013 09:52 AM
sjm8228
Jul 10, 2011 01:49 PM
kaabee
Jul 12, 2009 04:29 PM
AUDIFIELD
Jun 18, 2009 05:13 PM
