Coolant Question
Old Nov 9, 2006 | 02:23 PM
oz2281's Avatar
Member
Default Coolant Question
Hi Everyone, Was curious to know where to get the red coolant that Audi uses and if not what you would recommend.
Thanks
Old Nov 9, 2006 | 04:04 PM
CRAZYHAWK's Avatar
Default RE: Coolant Question
www.ecstuning.com
for G-12
or you could flush and use universal global yellow antifreeze.
Old Nov 9, 2006 | 07:22 PM
a4sport's Avatar
Yup. Dealership works too. Or any coolant if you flush the system. I just had mine flushed and had the shop put in orange dex-cool so I can get it at my local Autozone.
Plus it's better than spending $20 a gallon for G12 from the dealer.
Old Nov 9, 2006 | 07:41 PM
oz2281's Avatar
Member
Great, thanks for the replies guys. I appreciate the help.
Old Nov 11, 2006 | 11:06 PM
gmleeusa's Avatar
Hi, I got the green stuff in my 98 avant because just did timing belt n pump, dealer told me to go w/ pink g-12? does orange dex cool or global yellow work just as well and cheaper? n.bergen nj
Old Nov 12, 2006 | 01:15 AM
GeilKyle2's Avatar
audi says stick with pink g-12 due to it's additive package, I'm sure most coolants are similar and have similar additive packages, my take is stick with factory fluids because they are tested and fomualted to work best with the car, another thing to make sure is when mixing coolant to use distilled water, hard tap water contains many minerals which will lead to cooling system failures
Old Nov 12, 2006 | 10:32 AM
david9999's Avatar
Agree.
Old Nov 12, 2006 | 03:46 PM
CRAZYHAWK's Avatar
Global yellow works just as well. I've used it for the past 30K mi.
eddiefury
Nov 9, 2008 07:34 AM
bkcox_S4
Jul 3, 2008 01:56 PM
Armenian
Jun 22, 2007 06:29 PM
a4anonymous
Sep 26, 2005 06:56 PM
skull10
Jan 16, 2005 01:04 PM
