Cornering affecting coolant???
Whenever I take my 97 A4 1.8T on a fast corner I get a warning signal beeping from the electronic dash readout which flashes the coolant symbol warning. Can ANYONE explain why I am having this problem? Should I be getting my coolant checked or something?
Also, whenever I press the check car button (same as clock button) to check my car, the check goes through fine with no warning about coolant. Help please. Thanks for your time. |
RE: Cornering affecting coolant???
Is the coolant low in the tank
let me check. meanwhile can anyone give me advice on how to fix if coolant is low? Where to buy from? Dealership?
Yes get it from the dealer
As for fixing it, look for leaks |
My 96 does it every now and then. It doesn't leak or isn't low and will only do it on a fast hard corner or if I'm playing a little too hard in the dirt. :D
now it does it when im taking a corner at about 40. My question is: Is the Audi's coolant supposed to last the entire life of the car? Or will the coolant of all cars run low at some point after so many miles?
My 97 A4 has 120k on it. Should I be looking for a leak? Or is it possible that after my mileage it is just running low? |
coolant should be checked as often as possible (water evaporates with heat) and changed every 2 years with a 50/50 mix antifreeze
your coolant level is probably a little low. you'll have to get it from a dealership or euro tuner shop. make sure you get "G12" coolant.
| All times are GMT -4. The time now is 06:52 AM. |
