couple mechanical problems
well since your running higher boost without a colder plug you probably need to gap them down a bit...im running 14pis on my MBC, and it was doin the same thing...i gapped them to .030 it runs much better in result...give it a try
ORIGINAL: Dunzie182
as far as i know the sparkplugs are stock and at the stock gap
and where is my starter located?
It should be at least 12.5V's. Keep it there and have someone crank then engine and see what the voltage drops to. It shouldn't drop below 10V's. If these are ok replace the starter.
