couple of questions
Old Nov 21, 2007 | 12:39 AM
yusong71's Avatar
Default couple of questions
Hi guys,
I've bought A4 99 Q 2.8 couple weeks ago, and there's no owner's manual...so I have some basic questions about the car.
1. how to adjust the time in the cluster? Mine is still in the day light saving time zone....
2. What's the spec of tire pressure?
3. Mine has 205/55/16 tires with five spoke wheel. Is this OEM?
4. What is the headlight spec? H1 or H7?
Thanks in advance!!
Old Nov 21, 2007 | 12:43 AM
hiwords's Avatar
Default RE: couple of questions
tire pressure is on the tire. believe it's 44 or so
yes the wheels are OEM size. there are alot of 5 spoke wheels in the world but our cars did come with a 5 spoke type but idk if were talkin bout the same 5 spoke. pics would help
and H7
no idea bout cluster as urs is probably differnt than mine
Old Nov 21, 2007 | 12:44 AM
jsgrabo's Avatar
1. i dont pay attention to mine
2. i think ~30psi; look on the tires
3. yes
4. h7 low/highs and h1 for the fogs
edit: beat to it!
Old Nov 21, 2007 | 01:30 AM
yusong71's Avatar
Thanks guys..
The clock in my cluster is a two-needle type one, not digital type. It's confusing sometimes cause time is still one hour ahead of real time.
Old Nov 21, 2007 | 02:25 AM
Trey25's Avatar
look at the bottom of cluster you see too umm...*****. Pull and hold the left **** till the clock hands move to the desired time. Tire pressure specs are on the inside of the gas cover.
Old Nov 21, 2007 | 02:57 PM
ImTheDevil's Avatar
Usually the tire pressure marking on the tire is a max pressure, not a recommended pressure. Many cars may use the same tire, but require different inflation pressures for various reasons, including weight distribution and overall vehicle weight. On my 99, the tire pressure info is on the inside of the gas door. Look there, or on a label in the driver's door jamb.
kopez03
Nov 16, 2011 08:44 PM
teedins2133
Sep 30, 2011 11:03 PM
dbn23quattro
Jun 8, 2009 09:56 PM
thepirate
Dec 11, 2006 01:50 PM
Hopin4A4
Apr 8, 2005 03:58 PM
