cv joint going...
Old Jun 14, 2007 | 11:04 PM
specialK4's Avatar
Default cv joint going...
Hey guys,
Just a few quick questions my front right cv joint is going i hear clicking when im turning right etc..
Wanted to know how hard it is to replace the front right cv joint on an A4 1996 V6, also if anyone has links to a how to do that would be great.
I found this cv joint kit on-line is this the correct one for the right side or does it not matter? http://replacement.autopartswarehous...t&dp=false
thank you
Old Jun 15, 2007 | 12:36 AM
a4 1.8t's Avatar
Default RE: cv joint going...
http://www.ecstuning.com/stage/edpd/...ory=Driveshaft
i would just get the axle or the cv joint kit from here.. a lot cheaper and easier to swap out the entire thing
Old Jun 18, 2007 | 07:47 PM
specialK4's Avatar
what does the axle have to do with the cv joint??
Old Jun 18, 2007 | 08:33 PM
onepoint8tee's Avatar
They are connected to each other.......
Old Jun 18, 2007 | 08:42 PM
Trey25's Avatar
It would be better to buy the whole axle.
Old Jun 18, 2007 | 09:43 PM
trailboss's Avatar
This is why you should buy the whole axle and not replace the joint itself, Easy except for poping the cv joint over the c - clip.
Old Jun 18, 2007 | 10:11 PM
ILoveT's Avatar
I'm pretty sure it is the same with all cars. Replacing the whole axel is a lot easier to do than to repack the whole thing.
Old Jun 18, 2007 | 10:18 PM
ADubyaD's Avatar
SoCal Crew Member
yes do the whole thing..... but if it clicks when you turn it could be your tie rod ends.... what do you guys think?
Old Jun 18, 2007 | 10:29 PM
ILoveT's Avatar
Put it in reverse and turn the wheel to the right lock and then do circles.
ILoveT's Avatar
EDIT: Double post. I always had this problem on other forums.
