Detonating 1.8t?
Old Aug 23, 2006 | 11:11 AM
blkapra4's Avatar
Default Detonating 1.8t?
on really hot days if i punch it in my car the engine will click or detonate (only happens sporadically and only at first on really hot days) Is this normal? I want to chip the car but if its detonating occasionally on the reg program will i have problems? (i always use 93 oct from mobil)
Old Aug 23, 2006 | 11:22 AM
RLB6's Avatar
Default RE: Detonating 1.8t?
Oh, hell yeah you will have problems but the first thing is to find out IF and why you are detonating. Are you fueling up with 93 octane? Is your MAF faulty? Go get it VAG'd.
Old Aug 23, 2006 | 11:26 AM
blkapra4's Avatar
you can get it vagged at pep boys right?
Old Aug 23, 2006 | 11:32 AM
RLB6's Avatar
Yep. You can get a diagnotics test from there or autozone as well.
Old Aug 23, 2006 | 12:38 PM
blkapra4's Avatar
i bought the car used with 75k on it i since did the tb and went to change the diverter valve and found a aftermarket one in there could something the prev owner had done made the car this way?
Old Aug 23, 2006 | 12:46 PM
RLB6's Avatar
That could be a sign of how the car was driven or its purpose for the previous owner, but not neccesarily. I'd just get it VAG'd.
Old Aug 23, 2006 | 12:48 PM
blkapra4's Avatar
k
Old Aug 23, 2006 | 02:09 PM
blkapra4's Avatar
so a stock 1.8t will never detonate? not even if its 98 out?
Old Aug 23, 2006 | 02:26 PM
InsaneHatter's Avatar
most likely not... maybe after too many runs it will heatsoak the intercooler, but i dont think it will detonate. Maybe you have a vaccum leak , running a little lean.. which would cause detonation at high temps.
Old Aug 23, 2006 | 05:54 PM
blkapra4's Avatar
do chipped cars detonate alot in the heat?
