DIAGNOSTIC LOG HELP!!!
Old Feb 28, 2005 | 04:33 PM
Aliel's Avatar
Default DIAGNOSTIC LOG HELP!!!
Guys I'm sorry to ask you but I just got my VAG-COM today and I have no idea what these error codes mean. I need advices. Thank you
VAG-COM Version: 500.8-UD
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01: Engine
Controller: 8D0 907 557 P
Component: 1.8L R4/5VT MOTR HS D07
Coding: 06201
Shop #: WSC 06335
1 Fault Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-00 - -
Readiness: 0110 0101
Address 35: Centr. Locks
Controller: 8L0 862 257 N
Component: CV-Pump D10
Coding: 16140
Shop #: WSC 06335
8 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
00991 - Interior Lights
28-00 - Short to B+
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
Old Feb 28, 2005 | 07:23 PM
david9999's Avatar
Default RE: DIAGNOSTIC LOG HELP!!!
The central lock ones mean that the alarm has been tripped at sometime in the past. Just clear them. Same with the interior light. I cleared it on my car and it didn't come back.
The engine code, someone else with the CD will have to help you with.
Old Feb 28, 2005 | 07:38 PM
brrman's Avatar
Have you ever pulled your ECU or changed your battery? if not, one of them has probably been replaced/swapped in the past.
The 18010 code is normally a result of the ECU being pulled or the battery being disconnected or changed. Clear it and it should not come back.
Aliel's Avatar
Thanks for the help man. Sorry to bother u again but what about these?
00955 - Key 1
00956 - Key 2
Old Feb 28, 2005 | 07:41 PM
Aliel's Avatar
I know the battery was removed when I got the transmission replaced and the ECU was removed when I changed the chip. But that happend to me before with the old chip. My mechanic cleared that code and it came back again.
Old Feb 28, 2005 | 08:32 PM
Jestnomen's Avatar
6th Gear
Clear the central locking pump codes, they are very common and don't necessarily mean anything is wrong. I had them too when I first scanned my car. Hasnt returned in a year and a half.
Old Mar 1, 2005 | 03:09 AM
Aliel's Avatar
Ok guys i feel so dumb right now... I tried to clear the codes and it said something about switching into proffessional something... I have no idea how to do that. Please help
softwared
Mar 22, 2013 01:04 PM
Sultan35
Jul 18, 2010 11:16 PM
Sultan35
Jul 15, 2010 06:32 PM
wilbrass
Mar 26, 2008 03:43 PM
killerS4
Mar 9, 2008 09:35 PM
