dice ipod intergration.
Old Oct 31, 2006 | 02:21 AM
johnstef's Avatar
Default dice ipod intergration.
has anyone used this? If you have a trunk cd player would u connect this there or at the actual radio? when you are connected does the ipod only power up when the cd player is turned on. or is it charging the whole time?
Old Oct 31, 2006 | 04:40 AM
A4nicator's Avatar
Default RE: dice ipod intergration.
It connects to the head unit. I believe the dice is an all for 1 unit that charges as well. There are other companies that make Ipod integration kits. Im not sure if they do for audi, but it would be something to look into considering dice is expensive.
Old Oct 31, 2006 | 06:28 AM
socaljoe's Avatar
SoCal Crew Member
I got the Neo Ion from mp3yourcar.com, you can control the ipod from the head unit or the steering wheel controls
Old Oct 31, 2006 | 12:32 PM
Madcrazy10's Avatar
I just bought a DICE hookup for my car last week. I installed it myself. It wasn't very hard. I went to the dealer and had them pull out my radio (which they did for free which was nice). I then went home and hooked it up. I have the indash 6 disc changer so I'm not entrirely sure about the trunk setup but mine works just fine. It's pretty much a Y splitter harness. You plug the harness into the back of the headunit where the CD Changer goes and them you plug back in your CD Changer and your Ipod into the other ends of the harness. I then drilled a small hole in the back of the glove compartment to run the wire to the Ipod. My Ipod just sits in there.
On my Symphony II headunit I can hit "CD" once and get to the CD Changer and then I hit it again to access my Ipod. I also have ability to control the Ipod from the headunit (change playlists, shuffle through songs, fast foward) or open up the glove box and control the Ipod from there as well. It sounds and works just fine for me.
Old Oct 31, 2006 | 08:39 PM
A4nicator's Avatar
ORIGINAL: Madcrazy10
Good deal! How much did you pay? Where'd you get it? From Dice?
Old Oct 31, 2006 | 08:48 PM
Madcrazy10's Avatar
$150 approx.
www.enfigcarstereo.com
Old Oct 31, 2006 | 08:55 PM
twiggy114's Avatar
It's $144 here
Old Oct 31, 2006 | 09:01 PM
A4nicator's Avatar
$150 approx.
Enfig is good to deal with, but cheaper below
Old Oct 31, 2006 | 09:04 PM
A4nicator's Avatar
So Im assuming all Audi units have the same plugs?? That is a universal unit for 144.
ECS Tuning
Feb 21, 2014 12:19 PM
ECS Tuning
Feb 21, 2014 12:18 PM
tsells1
Mar 21, 2008 10:22 PM
johnstef
Jan 12, 2007 01:01 AM
S_R_N83
Oct 1, 2005 01:22 PM
