did a search, question about chipping automatic
Old Aug 10, 2005 | 10:55 PM
Beaner's Avatar
Default RE: did a search, question about chipping automatic
i have an auto and every ones like it cant handle the GIAC chip...wtf?
Old Aug 11, 2005 | 12:49 AM
flyinb501's Avatar
ORIGINAL: QuattroGT74
ORIGINAL: InsaneHatter
The only reason you would want/need a tip chip is to reduce the lag between shifts. It is not necessary, but you may want it. reduces shift by ... .8? if so thats 5x.8 = 4 seconds in 5 gears... will hinder 0-60 times a little....
That can't be right can it? Spend all that money for a car slower than a new H3?
WTF are you talkin about?
flyinb501's Avatar
They're wrong.
ORIGINAL: Beaner
Old Aug 11, 2005 | 01:55 AM
miked's Avatar
beaner youre fine with the auto with giac. but the other day you said you had a cvt, were you joking?
Old Aug 11, 2005 | 12:28 PM
QuattroGT74's Avatar
ORIGINAL: flyinb501
Exactly what YOU said here I believe?
"It will not hinder 0-60 times. It will improve them."
Nevermind.
Old Aug 12, 2005 | 01:59 AM
flyinb501's Avatar
The tip chip will improve 0-60 times. What are you talkin about with "spend all that money for a car slower than a new H3?
Old Aug 12, 2005 | 06:24 AM
IOKEPA's Avatar
ORIGINAL: jiggajaymz
ok, my roommate is getting a 2003 a4 1.8 avant with tip tonight with less than 15,000 miles on it. She's coming from a V8, and she's looking to add some more power to the 1.8. I know if she gets her ECU chipped she has to upgrade ther DV and that the tip chip reduces shift time to .2 seconds, but I need some clarity on other issues regarding chipping and auto.
1. Can an automatic handle the extra boost from the chip? I read a post that a torque converter blew once the chip was installed.
2. I also read that it's prudent to get a tip chip as well, what are the consequences if she only chips the ECU?
3. Finally, I read that there is a possible problem with the CEL when getting an ECU and tip chip. Aren't the 2003 a4's prone to electrical problems, is this something I should be worried about?
Thanks guyz appreciate the help.
my 2 cents...
first of all i didn't read what everyone else posted (too lazy) but here's my opinion and experience. i have an 2003 A4 1.8T tiptronic as well. i've had both the Neuspeed and GIAC chip on my car which now is at 72K, both good and never any problems with either. with our cars, you should be able to run any chip on the tiptronics without worrying about oveboosting. to get even more power, some tuners even offer the big injector option which has been known to put out a lot more torque. either way, i highly recommend getting a chip for her 1.8T. where are you located, if you're in the LA or SoCal area, i can give your friend a referral
tip chip is not availabe for the B6, at least not yet.
answer to question no.3 -- NO!
Old Aug 12, 2005 | 03:29 PM
  #18
brrman's Avatar
All you retards that keep joking about auto's being slower than manuals. bah. You have to be a very good driver in a manual to exploit the small difference. I've beaten several chipped manual A4's before in my tip avant. I could probably do it with a coffee in my hand too.
Old Aug 12, 2005 | 03:40 PM
  #19
audilover04's Avatar
Is the tip tranny in the B6 A4 the same as in the S4, cuz then you would be fine producing those type of power numbers 344/302?
Old Aug 12, 2005 | 05:49 PM
  #20
PandaXpress's Avatar
the tip trannys arent the same on the B6s at least casue we have 5 speed auto and u have 6 speed
but the new b7s have a 6 speed auto now
