Differences between no buzz joint and regular T on boost gauges.
Old Jul 26, 2006 | 07:24 PM
Jovian's Avatar
Default Differences between no buzz joint and regular T on boost gauges.
So after I installed my VDO APR boost gauge everything worked great except that buzzing sound the VDO gauges sometimes have. As suggested from some forum members I went to ECS Tuning to get the no buzz T joint to resolve the issue. Well it worked flawlessly and here are pictures of the two joins, old and nobuzz.
Here is the No Buzz one from ECS Tuning:
Here is the one given with my APR boost gauge:
Now the only big difference is that the no buzz one has a clear plastic filling on the outlet going to the boost gauge, there is a little larger than a pinhole made in the filling to let air through. So basically the end going to the boost gauge only has a very small opening while the other two are typical size.
I bet it wouldn’t be too hard to edit your current one by filling up one end with some sort of hard substance and drilling with a very tiny drill bit a hole, or maybe putting a toothpick or something you can pull out after the substance hardens.
Anyone have any ideas on what a good substance to fill this that would handle the PSI? Preferably a substance that is easy to work with and everyone has access to.
Old Jul 26, 2006 | 07:28 PM
a4autocrossr's Avatar
Default RE: Differences between no buzz joint and regular T on boost gauges.
kinda off topic here...but do you think you can possibly measure the sizes of the "arms" of the T...i need to get one but dont know what size is right..
thanks
--E
Old Jul 26, 2006 | 07:33 PM
Jovian's Avatar
Here is a pictuer of it up against a ruler:
Old Jul 26, 2006 | 07:45 PM
sorry i wasnt clear...the diameter if possible of the ends...thanks
and in trying to answer ur question i think it'd be safer to get an inline no buzz restictor than filling the holes..i know newsouthperformance has them
--E
AudiTurbo
Oct 5, 2009 09:03 AM
jojoenglish85
Nov 25, 2007 03:55 PM
kaklexicon
Apr 25, 2006 12:29 PM
Audi son
Mar 15, 2006 01:49 AM
Skibos
Apr 15, 2005 03:47 PM
