disable headlight washers
Old Sep 23, 2006 | 11:47 PM
lbraasch's Avatar
Default disable headlight washers
I'd like to disable my headlight washers b/c one of them sticks 'open' when used until i give it a nudge, and it goes back down. That, and i wash my car enough to not really need them.
Is it as easy as pulling a fuse? or is it not worth the trouble? I'd like to be able to wash my windshield of bugs at night w/o knowing the washer is stuck open and looking stupid.
Old Sep 23, 2006 | 11:49 PM
CRAZYHAWK's Avatar
Default RE: disable headlight washers
Spray silicone on them, they'll work.
Old Sep 24, 2006 | 01:32 AM
luvin_the_rings's Avatar
mine does the same thing except some of the wahser gets snagged on the bumper hole, i figure i just cut it a little bigger.
but silicone works like a charm
for that stick that just wont go away, use some grease or somthing, that's sure to work.
Old Sep 24, 2006 | 01:42 AM
aRIf's Avatar
take out evething and put a nudge on the hose and tight it with a metal clamp, the you will be fine. This is what I did.
Old Sep 24, 2006 | 02:44 AM
lbraasch's Avatar
silicon lube wehre? on the actual part that catches on the bumper?
Old Sep 24, 2006 | 03:30 AM
flyboy's Avatar
Or you could just unplug the motor that powers the headllight washers. Its at the bottom of the resivore.
Old Sep 24, 2006 | 04:34 AM
socal_A4's Avatar
I would just pull the fuse for it.. simple and effective
Old Sep 24, 2006 | 05:21 AM
BadLuckAudi's Avatar
except the fuse for that also runs a few other things that he might not want gone like the windshield washer.....
ORIGINAL: socal_A4
Old Sep 24, 2006 | 06:04 AM
socal_A4's Avatar
well thats too bad we all have to make sacrifices...lol..jk aid the problem then silicone seems to be the common cure
Old Sep 25, 2006 | 12:02 AM
lbraasch's Avatar
what kind of sillicon lube are you guys using? I went to autozone looking for silicon spray on lube, nad could only find tubes of liquid gasket.
Would white lithium grease work?
