DIY- color matched engine parts
Old Mar 4, 2007 | 03:47 AM
scotts custom's Avatar
Default DIY- color matched engine parts
Ok,
This it to make your engine parts like your air intake heat shield, engine cover and the air flow parts from front of the car to the air box.
You are going to need:
Sand paper
High heat engine spray paint form Kragen or another auto store. I used dupli-color engine enamel 500 degrees.
Tape to tape off where you don’t want paint[/ul]
First: take parts off and wash them really well with soap and water to get the dirt off.
Second: sand like you have never sanded before. The better you sand the better the end product will look. I used 600 grit to smooth it all out in the end.
Third:Take the part out of theengine bay and spray in a ventilated area.Spray evenly over all the parts you want painted and do not over spray.
Fourth: leave out in the sun to dry. Make sure it is dry before you put it back in your engine bay.
For the engine cover, I sprayed the rings and the “5v turbo” black first and hand painted silver between the rings and letters. Then covered that and spayed the rest silver.
It looks pretty awesome in person
Hope you like it. Feel free to pm me with questions. O and I am not responsible for anything you mess up.
Old Mar 4, 2007 | 04:54 AM
BaconBait's Avatar
Default RE: DIY- color matched engine parts
Very nice.
You may want to take the covers out of the engine bay before sanding them.
Old Mar 4, 2007 | 06:41 PM
Oops, i totaly said that wrong.
ya, take everything out first, wash, sand, spray and then put back in the engine bay. sorry i didnt make it clear.
thanks
Old Mar 4, 2007 | 07:10 PM
AudiCross's Avatar
thats siiiick. but....do you think it would look good with myyellow?
Old Mar 4, 2007 | 09:55 PM
turbo kraut's Avatar
Tech Guru
nice job
and you could paint the rings and the 5v turbo in yellow and leave everything else black
i have seen that done in silver with a black car, and it looks good........you might say it is already that way, but on a car with miles, the stuff starts to look old and worn
Old Mar 4, 2007 | 10:10 PM
onepoint8tee's Avatar
Looks nice and clean, but im affraid of what it will look like when it gets dirty and grimey. When they are black, it really helps camofloge all the grease, dirt, etc. It seems like itll be a high maint. thing to keep looking good.. But it does look nice, good DIY.
Old Mar 4, 2007 | 11:07 PM
Lazer Viking's Avatar
looks good with silver.. i think anything else would look ricey
Old Mar 4, 2007 | 11:16 PM
Thanks for the feed back.
If i had a yellow car, i would do what Turbo Kraut said and paint the rings and the 5v turbo yellow and leave everything else black or I would make the rings black and make everything else yellow. But that might look a little too weird or stand out too much.
Also, there really are not that many colors to choose from that are heat resistant. there is only like silver black , shiny black, grey, clear and maybe another.
Old Mar 4, 2007 | 11:22 PM
AudiCross's Avatar
well, i guess its worth a shot
i need a new engine cover anyway (mine is cracked i think the repair guys did it )
if it doesnt work out, ill can it and get a new one or sand it down and try another color
Old Mar 4, 2007 | 11:44 PM
smokeU's Avatar
i just go over mine with some armor all. it looks clean. if it was silver it would be constantly dirty in my case at least. I dont have time to work on my car anymore.. 8..(
