Do I need Alignment after Axle replacement?
Old Jan 13, 2007 | 12:40 AM
aRIf's Avatar
Default Do I need Alignment after Axle replacement?
FInally I got my front both side axle replacent done. No more cranking sound on turns and ready for cross-x
The problem is for some reason car is shakening at idle, on high speeds and right turns...
Do I need alignment ? Or any other reason ?
I can understand high speed and right turn shakes but wtf with shake at idle ?? [&:]
Any ideas ?
Old Jan 13, 2007 | 12:48 AM
wood_e's Avatar
Default RE: Do I need Alignment after Axle replacement?
Shake at idle when the car is moving or when stopped? Stopped wouldn't make sense...
Old Jan 13, 2007 | 12:51 AM
aRIf's Avatar
ORIGINAL: wood_e
when stopped. yeah I know. it does not make sence to me either [&:]
Car did not run one week but i do not think it should do anything bad.
Old Jan 13, 2007 | 01:11 AM
tractioncontrol's Avatar
No you don't need an alignment unless you moved the tir rod or sub frame.
Old Jan 13, 2007 | 01:12 AM
onepoint8tee's Avatar
Id like to know how you got this done WITHOUT YOUR JACK STANDS!???
Dont know about your problem.. If the tierod or any major suspension part was disconnected you would need an alignment. How much does the car shake at idle? No codes?
Old Jan 13, 2007 | 02:16 AM
If all you did was pull the lower ball joints out of the bottom of the spindle and pulled it out of the way to remove the cv shaft when you put it back in the alignment would be the same, I guess it would all depend on how the cv shaft was removed (I haven't had the opportunity to do one on an Audi yet but I'm sure I will be suprised like when I did the control arms).
aRIf's Avatar
I did not do it myself. I paid a guy to do it.
no codes.
Old Jan 13, 2007 | 02:32 AM
ORIGINAL: aRIf
no codes.
What are you doing tomorrow? Ill come check it out if you want.. For whatever its worth to you..... (your jack stands and $50 for the MAF)
Old Jan 16, 2007 | 03:25 PM
aRIf's Avatar
are bad motor mounts make car shake at idle at stop?
Old Jan 16, 2007 | 03:30 PM
techbod's Avatar
yes engine mounts would cause shacking at idleand no alignment not required for rear Axel replacement ( its rigid and fixed construction ).
