AudiForums.com
-   Audi A4 (https://www.audiforums.com/forum/audi-a4-8/)
-   -   dropping the car (https://www.audiforums.com/forum/audi-a4-8/dropping-car-21272/)
lamchop Dec 12, 2005 09:42 PM
dropping the car
My car has the non sport suspension, i love the way it goes over bumps, I was wondering if there is a way that i can drop the car and keep the same ride that i have know, i only want to drop the car for looks and not for handleing, any ideas? Thanks
98 A4 Turbo Dec 12, 2005 09:48 PM
RE: dropping the car
the lower u go... the worse the ride. As far as i kno, theres not any way to get around that
lamchop Dec 12, 2005 09:49 PM
what is the softest strut out there?
AUDI05 Dec 12, 2005 10:05 PM
softest strut?
you mean softest spring? the Eibach Pros (I have) drop the car about 1.2-1.4 inchs and still has a great ride. But I want to go real low, and thus I will have a hard ride, but i dont care about ride quality
juice88 Dec 12, 2005 10:06 PM
not unless u get coilover kits, i think
Kellya4 Dec 12, 2005 11:02 PM
I've got a 2000 a4 w/H&R sport springs and koni adjustable shocks. The ride is stiff, but still acceptable for everyday driving. The look is worth it though.
BFlan2001 Dec 12, 2005 11:07 PM
i was in your boat, so i went with the stock sport suspension. it only lowers it 20mm and the ride quality isn't compromised...if you need to be lower than that though, neuspeed makes the softest springs from what i've heard.
juju4uofa Dec 12, 2005 11:09 PM
The less travel you have the stiffer the ride will be and there's no way around that. If you were to lower the car with springs that were just shorter yet maintained the same spring rate, you would bottom out quite often. So, if you go lower you go stiffer.
lamchop Dec 13, 2005 04:55 PM
what springs and struts can i get that will give me the softest ride i can get dropped. will there be any differents if i go with coilovers?
headshok2002 Dec 13, 2005 05:15 PM
Coilovers are sort of wierd, in that the lower you go... the softer the ride gets (to a point)... but yeah, it still comes down to spring rate. A coilover will always have a stiffer rate than stock.
